25. aug 2012 Følger: 42 Følgere: 331 RC-enheder: 10 Annoncer: 2 Emner: 286 Svar: 802
skala speedbåd/motoryacht {{forumTopicSubject}}
hejsa rcg ja eftersøgte noget skala speedbåd/motoryacht lidt ala dem man ser i de danske lystbåde havne men synes ikke rigtig jeg kunne finde noget der var interressant men stødte så på den her svend på ebay fra tyskland ved godt den er noget større end dem man ser i lystbåde havene med blev sku lidt forelsket da jeg så den så måtte have sådan en
Robbe Najada båd
lidt specs på den
Length: 960 mm
Width: 300 mm
Scale: 1:15
Total displacement: 3600 g
Najade RC Boats, Semi-scale model of a luxury motor yacht to 1:15 scale from Robbe.
Just like the full-size prototype the Najade features a large, roomy cabin, an imposing flying bridge and a lusty power system to ensure an impressive top speed.
The propulsion system is based on a ROXXY 3656-06 brushless motor driving the propeller direct via the propeller shaft; the entire power system is included in the kit. Construction of this superb model is hastened by many pre-fabricated parts, including the glazing which is moulded in clear brown-tinted material.
The fittings set is supplied as standard, and contains all the detail items required to give the Najade a perfect
