586 visninger
Spar penge på din forsikring
mar 2007
Følger: 5 Følgere: 6 RC-enheder: 2 Emner: 62 Svar: 110
maj 2004
Følger: 154 Følgere: 151 RC-enheder: 11 Emner: 155 Svar: 1.449
Søg nu for fanden
Følger: 47 Følgere: 123 RC-enheder: 10 Emner: 123 Svar: 5.189
http://forum.teamxray.com/viewtopic.php?t=3111
Dette link føre dig til et forum hvor der er Pdf. manualer til NT18 bilerne til breakin
NT18T Ball Differential Setting and Break-in
VERY IMPORTANT! READ THIS!
Please note that the factory pre-assembled ball differential is pre-built but is NOT tightened. To enjoy long life and smooth performance of the differential, you need to break in both front and rear differentials properly. You will need to run the car several times for a short time, and each time tighten both differentials a small amount.
To tighten the differentials, remove the front/rear upper arms as described below, and use a Phillips screwdriver to tighten the diff adjustment screw.
Break-in Procedure
1. Run the car for the first time at only 1 throttle for 30-60 seconds.
2. Tighten both front and rear diffs slightly by 1/16 turn.
3. Run the car again for 2 minutes at 1 throttle.
4. Tighten both front and rear diffs slightly by 1/16 turn. The differential should still turn freely.
5. Run the car again for 5 minutes, this time up to 1 throttle.
6. Again tighten both front and rear diffs by 1/16 turn.
Now the differential should be tight enough. The differentials should still turn freely but it must slip with higher resistance.
XRAY NT18 Engine Fuel information:
For break-in and general running, use high-quality, market-available model car fuel for 1/10 nitro touring cars containing 16% nitromethane by volume ratio. Although you can obtain more power by increasing the nitromethane content, it will shorten engine life. We strongly recommend to use only standard fuel with 16% nitromethane.
mar 2007
Download denn PDF. http://www.teamxray.com/teamxray/showfile.php?file_id=2669
Kig på side 13 der ståe Engine Breakin
mar 2007
tilkørsel af nt18mt
