316 visninger
28. jan 2008 Følger: 57 Følgere: 52 RC-enheder: 13 Emner: 92 Svar: 882
xl-5 og big block special {{forumTopicSubject}}
vil de to fungere sammen da en titan også er 12 turns?
kan ikke huske 100% svaret men mener det var lars g som svarede noget henad at bigblock den var lige tørsdig nok så han ville ikke turde parre den med xl5 esc
jan 2008
og så fik du jo 2700 rabat he he
held og lykke med det..
kristian
dec 2007
Følger: 59 Følgere: 51 RC-enheder: 5 Emner: 119 Svar: 507
The Traxxas XL-5 Electronic Speed Control provides smooth and consistent throttle control for the enthusiast who wants to extract the most from their mild modified and stock motors. The XL-5 features EZ-Set® push-button setup for easy operation, three throttle profiles, 4-8 cell compatibility, and thermal shutdown production. High frequency operation combined with ultra low resistance make the XL-5 an efficient and ultra-smooth fully proportional speed control. The XL-5 is backed by the Traxxas Lifetime Electronics Warranty.
Patent-Pending Training Mode™
An exclusive feature that places the XL-5 ahead of the pack is the patent pending Training Mode. This feature reduces the overall power output of the XL-5 by 50% making it easier for new drivers to control their model. When they’re ready, simply change profiles to unleash full-throttle action. Only Traxxas has it!
New XL-5 ESC Features
* 15-turn motor limit for 540 size motors
* 12-turn motor limit for 550 size motors
* Fully-proportional forward, reverse, and braking control
* Programmable with three drive profiles:
o Sport Mode – Fwd / Brake / Rev
o Race Mode – Fwd / Brake
o Training Mode – 50% Fwd / Brake / 50% Rev
* EZ-Set® push-button setup
* Multi-color LED
* Thermal shutdown protection
* Efficient, low-loss MOSFET design
* High-capacity heat sink
* Smooth, high-frequency operation
* Easy installation in Traxxas models
* Backed by the Traxxas Lifetime Electronics warranty
XL-5 SPECIFICATIONS
Input voltage: 4-8 Cells (4.8 to 9.6 Volts DC)
Case Size: 1.23"W x 2.18"D x 0.61" H
Weight: 2.44 Ounce
Motor Limit: 15-turns* (540 Size)
12-turns* (550 Size)
On Resistance Forward: 0.007 Ohms
On Resistance Reverse: 0.014 Ohms
Peak Current - Forward: 100A
Peak Current - Reverse: 60A
Braking Current: 60A
Continuous Current: 14A
BEC Voltage: 6.0 VDC
BEC Current: 1A
Power Wire: 14 Gauge / 5"
Input Harness Wire: 26 Gauge / 9"
Transistor Type: MOSFET
PWM Frequency: 1600 Hz
Thermal Protection: Thermal shutdown
Profile selection: Profile 1: Sport Mode:
100% fwd, 100% brakes, 100% rev
Profile 2: Race Mode:
100% fwd, 100% brakes, no rev.
Profile 3: Patent Pending Training Mode™:
50% fwd, 100% brakes, 50% rev.
Single-button setup: Yes, Traxxas EZ-Set®
