1.372 visninger | Oprettet:
Traxxas dele, hvor..? {{forumTopicSubject}}
Nogen der kender nogle sider med hvor traxxas dele er billige..?
delene jeg skal bruge er :
Rear end required Traxxas parts:
TRA3655 Suspension arms
TRA3638 Shock tower
TRA3652 Rear Carriers
TRA1951 Drive lines
TRA2753 Stub axles
TRA3762 Ultra shocks
TRA3739 Hinge pins
TRA3775 Bearings
TRA1654 Hexes
TRA2754 hex pins
TRA3685 Washer
TRA3641 Upper links
TRA3642 Barrel screws
TRA2648 4x12 screws
Front end required Traxxas parts:
TRA5531 suspension arms
TRA5530 Bulkhead set
TRA5543 Steering bellcranks
TRA5532 Caster/Steering block set
TRA5538 Turnbuckle set (toe links)
TRA5544 Bellcrank posts
TRA5537 Spindles
TRA5542 Steering drag link
TRA5116 5x11x4mm bearings X2
TRA2579 3x15mm Button head screws
TRA5521 Suspension pin set
TRA3936 4x10mm Buttonhead machine screw
TRA3940 4x4 buttonhead (Blue ano)
ville være fedest hvis der var en side det har det hele ;P
Kommentarer på:  Traxxas dele, hvor..?
