Kommentarer på:  Olie og fedt til Rustler VXL
  • #1   16. jun 2009 tror ik..
  • #2   18. jun 2009 Jeg har fundet ud af det, fik svaret fra Traxxas selv
    Her har I svaret fra Traxxas:
    The diff lube and thrust bearing grease are used in pro ball differentials which you do not have unless you installed one.
    The shock oil is used in the shocks when you rebuild them.
    Use a light coating of silicone grease on the teeth of the transmission gears if you break one and put a replacement gear in.
    Best regards,
    TRAXXAS Customer Service
