536 visninger
Indstilling af endpoints {{forumTopicSubject}}
Hej Forum
Jeg har en Spektrum dx2e transmitter/sender og jeg har lige rekalibreret den. Men hvordan indstiller jeg hjulenes endpoints med denne transmitter?
Jeg har ikke kunne finde noget nogle steder. Det kan være at jeg skal have fat i en nyere transmitter? (dx4s eller dx5r)
maj 2015
jan 2013
Følger: 1 Følgere: 6 RC-enheder: 6 Emner: 20 Svar: 80
The travel function supports precise endpoint adjustments in
each direction for the steering and throttle channels.
1. Hold the trigger in the full brake position and the steering wheel
in full right position while powering on the transmitter. The LED
flashes rapidly, indicating the programming mode is active.
2. Throttle End Point: Hold the trigger in the full throttle position.
Turn the TH TRIM knob to adjust the full throttle end point.
3. Brake End Point: Hold the trigger in the full brake position.
Turn the TH TRIM knob to adjust the full brake end point.
Return the trigger to the center position.
4. Left Steering End Point: Hold the steering wheel in the full left
position. Turn the ST TRIM knob to adjust the left end point.
5. Right Steering End Point: Hold the steering wheel in the full
right position. Turn the ST TRIM knob to adjust the right end
point. Return the steering wheel to the center position.
6. Power off the transmitter to save the travel adjust settings.
The minimum Travel is 75%, and the Maximum travel is
150%. The default travel settings are 125% steering and
100% throttle
Fundet her>>> https://www.spektrumrc.com/ProdInfo/Files/SPM2335-Manual-EN.pdf
sep 2017
Følger: 1 Følgere: 2 RC-enheder: 1 Emner: 7 Svar: 27
sep 2017
sep 2017
